I don't know if these exist or not, but I bet if they do, someone on this forum will have used them so here goes
I am after an ES14 (Small Fitting Edison Screw style) Bulb to fit into a standard table lamp, but I want to also use it on 12V instead of 240V, so is there such a thing as a 12V version of the ES14 bulb? (The low wattage of an LED bulb means the DC current on an 12V LED Bulb will be around the same as a 240V Standard Bulb so the standard flex will be fine).
