Phantom
I went to start the MB Sprinter MH today and found that the 110 Amp starter battery was flat. This was rather surprising as it is normally kept topped up by solar and leisure batteries which appear still fully charged. So not sure if the issue is the starter battery itself, charge not going in, a current drain, or a combination of these?
The starter battery was showing 12.5v but when ignition turned to second position dropped to about 7v with dash lights flicking on and off to a clicking relay. When also hooked up to a second battery all seemed normal though just not enough power to spin the motor over enough. I'm charging the starter battery overnight so will see how it is tomorrow.
The set up has worked just fine ever since we bought the MH nearly 2 years ago. It has a 120w solar panel and the controller visually seems to be working okay. There is a Van-bitz battery master fitted to the leisure batteries that is supposed to send excess charge to the starter battery. I've checked the fuses on the wires connected to the starter battery and they are all okay though not sure if there are any related others anywhere? The MH has only been stood for 1 month since our last trip with a small draw from the alarm so it seems a bit odd really, any ideas what the issue could likely be?
Here's a pic of the starter battery wires. I guess that the fuses on the right (yellow 10Amp & Green 30Amp) are where the starter battery should get it's charge from the leisure side?
