jagmanx
Hello
We will be in Canada and USA in the summer.
EHU is no go
So wondering if I can use a small 12V battery charger to maintain the battery in the evening when the gas heating is being used.
https://www.walmart.com/ip/EverStar...-8ab-16f4b7ae0aeaae&athancid=null&athena=true
My thoughts are to use this when 110V EHU is available
To attach it direct to the LB with the main Electrical switch is on.
The fridge would remain on Gas
I am slightly concerned that this may not work or indeed cause a conflict
I have a solar panel which feeds the LB directly.
The power is not great but even just 3 amps will take the presuure off the LB when the Gas (TRUMA) heating is blowing.
2nd question
How many amps will the blower use when it is active (which is often only for 10 mins or so
Thanks
EHU is no go
2nd question
Thanks
