jagmanx
I have a Calira EVS 36/20 power management unit
I briefly considered Lithium but have gone for 2 x 100AH "Normal batteries" much cheaper at just under £300
I enquired of the German manufacturers and got this reply
Many thanks for your inquiry.
The EVS 36/20 has a battery charging curve IUoU.
The final charge voltage is 14.4 volts and the trickle charge voltage is 13.8 volts.
You have to clarify whether the BMS of the desired BLiFePo4 battery allows this
Not conclusive
However I also have a pdf of the manual if anyone wants it
Not conclusive
