Exwindsurfer
His Ducato won't have a smart alternator.Some good eye opening videos on you tube . some by Sterling explaining the problems .with s mart alternators.
I shall give this a try when I next get to the van. Thankyou.Assuming that you have a standard alternator and a digital voltmeter, start you vehicle and check voltage at vehicle battery, then rev up the engine to say 1500-2000 rpm, the voltage needs to be above 14v, better a bit higher at about 14,4v assuming the batteries are charged, might have to run it for a few minutes. Check the voltage at the liesure battery, it should be the same-ish if all charged, again run for a few minutes. To check the amps output of the alternator switch on headlights, heater blower, and recheck voltages, here you would hope to get 14v at the vehicle battery, perhaps a bit less at liesure battery, now also switch on your fridge and recheck at both batteries. Hopefully you will have 13.8 and 13.5, which means it is balancing the load that you have switched on. It will charge at these voltages but will take longer. If you have a clamp on ammeter you can use that to check power going into the battery, a digital voltmeter is much better that a analog version.
That is not necessarily actually very promisingLeft the van on hook up for 36hrs. Voltage has increased to 13.99 volts. (multi meter reading)
Being on hookup for 36 hours, you would expect the battery to have got a full charge (which would have taken the battery to probably/ideally around 14.4V or so - could be more if any temperature compensation) and then the charger would, if it is a multi-stage charger, dropped into a Float mode, in which it will drop the charger voltage to between 13.6V-13.8V, depending on how it is setup.
This is an example of the kind of charging pattern you want on a Lead Acid Battery (my batteries like a lower 14.2V charge rather than 14.4V hence why that is low on this graph)
My charger also has a Storage Mode which lowers the voltage again (not all chargers do).
By 36 Hours if your battery is not in a Float or Storage mode situation, then either the Battery has a problem or the Charger is not suitable for this use (much to small an output or a basic one with a set output)
What mains charger have you got? It sounds like one in which you should not actually leave plugged in for so long as it is not letting the battery go into float OR it is not reaching a high enough voltage to fully charge the battery. Either way, I'd suggest it is something you look into further to best look after your battery.
Now it is possible your charger is in float and it is very cold where you are so the temperature compensation has increased the voltage by around 0.2V but I am going to guess that is not the case and what I said above still stands for your setup.
I was answering the last part only and his update about his battery after a day and a half on a mains chargerHi,
Looking at your graph am I reading that right that your in vehicle charger starts charging at 120 amps?I assume you must have a large battery bank and probably cook by electric? The graph shows very well what you system does and at what state it is in the process.
Now if Paul had you system we would know exactly what and where his state of charge was. Unfortunately he only appears to have a multi meter. His initial question, (I believe), was about driving 50miles and his leisure battery was not charged. If it was me I would start with the basics vehicle test first, see what readings he gets and go from there.
Sorry only my opinion.![]()
"Showing over 14v is a sign that the batteries are not yet fully charged. Only when the voltage drops back to 13.7v showing that the regulators thinks they're full.I don't know how you have come to that conclusion Tony as for instance in my self built installation where I have a van battery which is connected via a split charge relay to 2 leisure batteries and at the end of a 2 to 3 hour journey all 3 batteries are showing over 14v when tested.
Since being on mains charge the moho has been returned to staorage and back (4miles) and sat for 10days (with some i/p from solar).
On return home today : LB was 13.5V and VB was 12.76V. (LB = leisure battery, VB=Van battery)
As suggested I took the following measurements (without being hooked up ) :
Switched on headlights and blower :
Switched on Fridge :
This appears to be close to your expectations ?
Is this all telling me that it is unlikely I will achieve a fully charged leisure battery using the alternator alone ?
Paul
I think others have covered it but at that stage - assuming the battery voltage was still increasing - I would say 80% would be pushing it. To get to 100% the voltage would need to reach well over 14 V and then be held there for at least a couple of hours at which time it would still be only 90% full. That last 10% is the hard partI don't know how you have come to that conclusion Tony as for instance in my self built installation where I have a van battery which is connected via a split charge relay to 2 leisure batteries and at the end of a 2 to 3 hour journey all 3 batteries are showing over 14v when tested.
A standard alternator regulator will not drop back to 13.7v, voltage will remain above 14, depending on the load and revs. Test bench situation; It only monitors the voltage, as the battery voltage increases it reduces the amperage in the rotor circuit, thus reducing the alternator output. Note this is with a standard regulator fitted in a standard alternator."Showing over 14v is a sign that the batteries are not yet fully charged. Only when the voltage drops back to 13.7v showing that the regulators thinks they're full.
The alternator is charging the starter battery. The habitation batteries have a different state of charge, needing different treatment, which a split charge system cannot give.
I posted this earlier which from my 2017 Ducato. I will be fitting a B2B before I fit a second battery unlike many motorhomes I come across. A single Battery "fully charged" will last me, coupled with my decent solar set up, for a couple of nights.Here is charging from a 2017 Fiat Ducato alternator. This was a drive down a motorway, a bit stop - start and slow progress due to an accident. I will be fitting a B2B charger
[/QUOTE]Looking at your graph I assume that you didn't start to drive until approx. 09.00, and your battery was already 75% charged. TBH, I wondered if you had your fridge on 12v and other electrics on, as that would explain with your stop start traffic the lower than expected readings, for volts and amps. You also say you have solar, that could also differ some readings depending on conditions and where connected in. So lots of variables to take into account, which is why I said in my post test bench conditions. What time did you stop driving as with solar added in from say 10.00 more variables & clouds.
Your Victron will obviously give you a much better idea of your battery and charging system than just a voltmeter. Other systems are also available.
Will be interesting to see your results later, before and after B2B, ideally with identical conditions though. Is your alternator standard? and do you have a standard split charge system?
QUOTE="xsilvergs, post: 172270, member: 5434"]
Without a B2B I would have two partially charged batteries which seems a bit pointless.
Thanks to Victron I know the SOC of my batteries and can see the weak link is the alternator.
Come May when I fit a B2B I will post the results, sort of before and after graphs.
My battery days go back to the early 80's, I worked on aircraft so doing capacity tests etc on lead and alkaline batteries/cells.Yes the charge current & voltage seem low to me after about 09.30, but your SOC seem good, according to your Victron, but it took a long time to get there. Did you check for volts drop on both sides + & - side. As a separate unit with separate wiring a B2B may give you a better charge, but if your system was showing a 40amp charge dropping to 20amps perhaps not so much.
My battery testing days go back to pre-maintenance free, when all battery tops could be removed and a Specific Gravity test and a Cadmium Voltage test cold be done on each cell. I wonder if anyone has that capability here, having a standard liesure wet battery, a hydrometer and a Victron. Just interested to see if all readings matched.
