Which Satellite Dish
RoaminRog
We have been looking at satellite dishes to compliment our Cello Traveller tv.
We rather fancy the Selfsat H50D2 which apparently is comparable to an 80cm dish, and it’s claimed that reception is fairly good most of the way down to the foreign.
Has anyone any advice or experience in this area please.
Don't know which I'd choose streamin or satellite now. But if satellite I.d definitely go for a manual 80 cm dish like which I've used for 10 yrs on 2 vans now a Maxview still giving us some UK channels on the Algarve. Never needing any updates which seem to let a lot down when changes are needed with practice locating the sat is simple just by seeing where dishs in the area point and where the sun should be at midday
I have a Snipe on my van but don't use it, we have been using a Firestick for the last couple of years and I'm now thinking of removing the Snipe to make room for more solar.
We get everything on the Firestick we need and with a cheap cable we also watch movies etc. from a external HDD or memory stick.
Del
Del
I am a sport addict so have a roof mounted auto dish and use a sky box onboard to watch cricket etc on Sky.
How does streaming work ? Is it live ? Could I watch Sky etc ?
Does it rely on an internet connection so would be limited in out of the way locations etc if no signal ? I’ve never failed to have a satellite signal anywhere in the uk.
Just curious and may consider it in the future .
Del
Thanks, will check out the Firestick.
Standard Firestick is on offer at £19.99 at the moment but I would recommend the 4K one, also on offer at £29.99, it is faster and picks up weaker wifi signals
If you want a standard one Rog pm me your address as I have a spare one lying around somewhere, FOC and I will disinfect it before posting :ROFLMAO:
Will pm you Terry
We have one in the van Terry good bit of kit.I just tether it to my phone .
It does need internet but I've found over the last couple of years that it's getting better and better and on the occassions I don't have any internet I watch something of my external HDD and I very rarely watch anything in the summer months. Sky are moving to streaming themselves and if you have Sky Q you're actually streaming to the other rooms from the main box and as home internet gets faster and more available across the country it makes sense for them to go the streaming route. They have Sky NOW which is a streaming service and they also have their Sky Go app which is available for the Firestick now. New housing estates around Shropshire aren't allowing Sky dishes to be installed so Sky have a large communal dish for those developments so the cost savings by streaming would be pretty good.
If you have never had any problems getting finding the satellite then your best keeping it, I on the other hand did have problems finding a satellite in some remote parts of Wales and Shropshire but got a decent mobile signal (even the Sky installer struggled at the bungalow I used rent in Telford). I also use a Apeman projector so I save on power as this is 5v USB powered like the Anker Soundcore speaker and Firestick so I can run it all of one of my Anker powerbanks :) I also have a pretty good mobile router setup in the van since going full time.
Del
If you have a router you can connect the Firestick using ethernet with this lead and this hub, this is the setup I use but there are cheaper hubs that should work, eliminates the poor wifi signal and you can watch stuff off your memory stick or external HDD.
Del
Is there any problem using them outside the uk couldn't decide what Amazon where saying
BBC iplayer, Ch4 & Ch5 worked for me using a 3 data sim without a VPN, ITV will work if you pay £3.99pm for ITV Hub+, all the catch up programmes but not live TV
ITV Hub+ said:
Ad-free*
  • Catch up abroad
  • Download on iOS
  • Unlimited on demand
  • 6 live channels
  • Full series boxsets
£3.99 per month
Hub+ benefits available in EU countries only. Excludes live TV*
Amazon Prime TV works everywhere as do almost of the other apps you can install such as Netflix, youtube,
Would you have to pay for ITV if a VPN was used Terry?
