Obanboy666
It’s been mentioned often about a decent leisure battery should be 1amp @ 300grams so a decent 100 amp battery should be 30kg.A proper leisure battery should be of the deep cycle type, less likely to be damaged by a deep discharge but not capable of the higher currents needed for engine starting. A proper 100Ah leisure battery is likely to weigh nearer to 30kg than 20kg.
I went through most of the leisure batteries Alpha had and didn’t find one that met the above criteria.
The Trojan deep cycle we’re the nearest at approx 275gms per amp.
