Mark135
I have a Bailey Autograph MH that has a split charge (or VSR) relay to charge the LB's. I have fitted a pair of 100ah LiFePO4 batteries and want to charge them quicker when the engine is running. I have a stand alone 40a mains charger which I intend to use off my inverter when driving using the vehicle (starter) battery. I will wire and fuse this and use a 200a relay to ensure it's only powered when the ignition is on. I will manually change the inverter battery connections with a 175a Anderson connector so either the vehicle battery or LB's are connected at a time. The mains charger connects to the LB's through the other side of the Anderson plug so it's impossible to use the LB's to try and charge themselves.
Sorry, a bit long winded but I think this will function similarly to a B2B albeit with some efficiency loss. My question is: Do I need to disconnect the existing SCR/VSR or is it OK to run both at the same time? The SCR is supplying a constant 14.2 v (measured at the cab 12v socket), the charger peak voltage is 14.6v
Thanks in advance.
Mark
Thanks in advance.
Mark
