Just to be sure you have your meter setup correctly. Measure the short circuit current across an disposable AA battery. The current shouldn't be enough to blow the fuse in the meter, but enough to check your settings.I have a 100 watt panel which I am not sure if working ok. Removed panel cables from controller. 15 volts coming to panel from indirect sun..checked with meter set to 10-amp current only getting 0.2 amps. Not sure what can be wrong , if anything... opinions please
Thanks, I am using an mppt controller epever genuine, not chinese copy .Sounds about right, 19v or more in summer and much more amps, are you running a mppt regulator which will give a 20% or more extra charge.
Can't see that making much difference nowt + plus 20% is still nowtSounds about right, 19v or more in summer and much more amps, are you running a mppt regulator which will give a 20% or more extra charge.
Solar panels next to useless in winter, no power going in=no power out?.I have a 100 watt panel which I am not sure if working ok. Removed panel cables from controller. 15 volts coming to panel from indirect sun..checked with meter set to 10-amp current only getting 0.2 amps. Not sure what can be wrong , if anything... opinions please
Tilting your panels will make a big difference. Also, any patch of shadow on the panel will really reduce the output.
Me and Rae have been tilting our panels for over a year now so know how much difference it make .My panels are remote controlled so I can put them at any angle I want .Tilting your panels will make a big difference. Also, any patch of shadow on the panel will really reduce the output.
The panels where surprisingly cheap to tilt and not a lot of effort .How about this for an idea? Instead of going to the effort of making tilting panels, mount them vertical. Just fix them to the side of your van.
Your latitude is approximately the max elevation of the sun.
You're correct in what you say. I already have tilting panels and can see the benefits.The panels where surprisingly cheap to tilt and not a lot of effort .
With tilting panels you still need to park with the panels facing the sun, unless they are rotating too, or have panels that can tilt in more than one axis.Plus not all parking spaces / pitches face East/West
