Channelcrosser
I removed the exterior vent grille the other day only to find a black single core cable hanging loose from the Dometic ignition controller.
(Type p-810).
At the bottom (side in photo) of the controller is an 8 way multi plug. The first is not used and then the next three from the left go to the electronics box. Then there are four black cables. The first is the one that is going nowhere. The remaining three 6,7,8 all go to the gas valve.
Does anybody know where the black cable from terminal 5 should go to please??
Any help would be appreciated
Thank you
Channelcrosser
(Type p-810).
Thank you
Channelcrosser
