Wrighpm
The firesticks meet no current British Standard. They have no kitemark. Fires are put out by.... removing the fuel or cooling the fire below ignition temperature or smothering. The firestick smothers a fire by excluding oxygen. It is dubious to say they would be safe to operate in a confined space as humans need air. Also I would suggest there is no cooling effect so unless the fuel and ignition source are separated once the most has wafted away a class A fire would likey re-ignite. Once used you have no reserve to further fight the fire. A water mist or dry powder extinguisher has more control and does not need to be full expended in one attack. By far and away the best and least messy addition everyone should have is a fire blanket.... cheap and extremely effective.
I do thank the poster of this article because of the useful focus it has given to fire safety. I am a retired fire safety officer. If I were to use a firestick I would set it off in the moho stainless sink...leave smartly and close the door ... then call the fire brigade if in any doubt. When re-openning the door you would allow an in-rush of air....so be prepared by having a couple of buckets of water or borrowed extinguisher to hand.
