Deleted member 4850
New 120w solar panel fitted on our MH and working well, Thanks again to Wildebus, Trevskoda and others for advice, Opinions please.
What to do with the old one, Heres a thought
I could fit the old Auto sleepers 80w panel on my workshop roof, I am at present awaiting a delivery of a basic controller, Reading online and listings on this forum regarding voltage drop in cable. The cable on the panel is 4mm joined to an 2.5mm extension cable going to the Sargent panel, that I assume was applied when MH was built looks to thin for me.
I assume the 2.5mm cable should also be 4mm. I have found a supplier with 4.5mm strand twin core flat cable its neater to fit. Or is this to big for use? or should I use 2 separate 4mm cables??.
When up and running it will power a 68amh AGM battery that will in theory run the 12v lights in our back garden, I hope
