Sorry should have been replenishing what was used during hours of darkness
The difference in readings between a full day and when dark is a good point. It depends how the device you are reading the info from is using the data and the difference could quite literally be night and day
So taking your setup where the only input into the battery is from Solar ...
If the readings are from a Battery Monitor, the Amp-Hours could be the net difference between Power Used and Power Harvested, so the actual Solar harvested is greater than the value as power loads around the motorhome could be effectively fed directly from the solar (such as a Starter Battery trickle charger).
If the readings are from a Monitor reading the Solar Controller, that would be the actual amount of Solar harvested.
May or may not be of interest, but these two screenshots I just did may illustrate this?
This is the Battery Monitor in my Motorhome:
Right now is getting 3.3A fed into the Battery from the Solar
And at the same time, this is the Solar 'Monitor' for the Solar Roof Panels:
It is feeding 7.40A into the system from the panels (about 100W coming in from the 450W array)
Which means 4.10A (7.40 - 3.30) is being used by the Motorhome and the battery is not providing any power. So it does depend very much on what point you are measuring to know what is what.
In your case, the solar is keeping the batteries fully replenished I would say as the power coming in from a decent sized array is low and you have a very low demand right now..
In my case, the solar would be providing all that it is capable of (which is not a lot in the current weather situation) to try and raise that -363.9Ah back to 0Ah (Full).
The difference between our setups would be you have turned everything off and isolated the batteries, etc so have no notable power demands whereas I have my Electric Fridge/Freezer running as well as having random things like internet routers and USB sockets powered.
