GMJ
Coming back from a month away, yesterday we encountered several issues which I'd be really grateful for some insight into if possible. Our MH is a 2017 Autotrail Comanche with a Sargent EC500 Power Supply unit with an EC480 Control Panel above the door. It has a small bank of fuses set into the floor immediately behind the drivers seat which would be above the hab batteries which are underneath in a locker accessible from outside.
Issue No1 - The small bank of fuses set in the floor behind the drivers seat (above the leisure batteries) started buzzing yesterday: an on/off regular buzz. This only happens when the ignition is not on. When I remove the 5A Tan coloured fuse marked 'Marker Lights' the buzzer stops. I have checked the fuse (looks OK) and also changed the fuse, to no avail. With a new fuse in, it still buzzes. As it stops buzzing with the ignition on I'm guessing it is something to do with the 12v electrics?
Issue No2 - The ECU500 has twice come up with a warning that the 'Vehicle Battery Voltage is Low'. This is accompanied by the bleeping warning and clears after 1 minute or so. The EC480 panel then shows the vehicle battery level as either around 12v or the display goes haywire between Green and Red and the max/min voltage. NB I fitted a brand new vehicle battery in April and the MH starts first time, no problem.
Issue No3 - The EC500 has started to switch itself off after only being on for a matter of seconds. I'm guessing that this could be a fail safe and maybe to do with the other problems.
Has anyone had any of the above issues? Or if not, could anyone make any sensible suggestions as to the causes and what I can do to solve? We are due to be going away again in 3 weeks time so I need to get this sorted sharpish.
I'm happy to add any more info; answer questions; or add piccies if needed.
Thanks
Thanks
