Ducato demist fan
MykCamper
My demister fan is only working on maximum setting 4, I had this problem several years ago but cannot remember how I fixed it?😩😤
Must be going senile!🥺
Do remember 🤔 it was a loose connection in the dash area but can't remember how I got access! 😤
Anyone!!?🤭
Mike🤪
Thanks, Kev. I hope I don't need to do this job, but, if I do, I'll be asking for a reminder of where the Video is! Can it be added to the Resouce Section so that non techies like me have what is a really simple step-by-step guide to follow?
Didn't know we had one but you can download from YT, and of course the thread is aptly name even for us thickos :D :D
It's a doddle to do Steve
I might take up the challenge to prove you wrong, Jeff! My father was an old fahioned mechanic, trained in the Army in mid 1930s at a time when making your own spanners was quite common. His Parade Ground assessment of my abilities was that I would never make a mechanic as long as I had a hole up my rear end, which I took to mean that I had limited potential :D
But, on a brighter note, I have found a link for the entire kit on Amazon if Mike, or anyone else needs it! Ducato Complete Blower Motor kit incl 5.5mm bolt
You need to replace the heater resistor as pudsey says Mike
It's All come flowing back!😇
Last time I unplugged it cleaned and Vaselined the connectors and plugged it back in! Hey Pressto it worked OK!😊
Might not be so lucky this time but its raining 🐈‍⬛&🐕 so I will have to live with the hurricane or drive faster to get free air!😂
Gave the plug a good shake and I have 4 working settings!😊
Magic! Thanks for the Video, Steve.
I owe you one 🍺or🍻 !😋😂
Mike
i know my switch is broke as ive changed the easy part and it still doesnt work i think it is a bit of a job to change the switch ??
Mike
Won't be long before you need to sort the resistor out ....
Happened to the last 3 work ducato,I've had ...
All started with wiggling the plug to get working ...
It's typical bad design
