Mr and Mrs Tupcox
Hi last job in our van 12v power system now need a mains charger ,to charge our 460 ah lithium when on ehl .don't want to speed loads of money .£100/300..
how often do you expect to be on EHU and how much do you expect to typically expect to take out the 460AH battery? that determines how powerful a charger you need.Hi last job in our van 12v power system now need a mains charger ,to charge our 460 ah lithium when on ehl .don't want to speed loads of money .£100/300..
Thanks.how often do you expect to be on EHU and how much do you expect to typically expect to take out the 460AH battery? that determines how powerful a charger you need.
If you are overnighting on a site - say arriving at 6PM, departing at 10AM, then you have 15 hours of Charging (knocking off 1Hr for setting up/breaking down camp). If you have taken a lot out the battery, then might need a 30A charger to be fully charged before departing. If you are topping up, then a smaller charger would suffice.
Given the charger is likely to be on and running overnight, I would avoid one with a fan - they can be very annoying at night.
Been very happy with theHi last job in our van 12v power system now need a mains charger ,to charge our 460 ah lithium when on ehl .don't want to speed loads of money .£100/300..
ThanksBeen very happy with the
Victron Energy Blue Smart IP22 Charger 12/30
I fitted to look after our 3 x 100ah agm batteries .
Thanks I've looked at that one ..I've just fitted one of theses from Alpha £120 40 amp lithium charger and it work a treat .I've got 4 x 100amp Relion lithium batteries.
JeffView attachment 65449
It's a plug and play one lololThanks I've looked at that one ..
Not bad price..
