The sad face was in sympathy for you having a similar problem Geoff, it seemed the most appropriate icon.FWIW, I made post #33 because the sound coming from my van's rear view system sounds very much like the sound in the recording attached to the OP but with the addition of a tiny bit of hiss. So I was surprised to see a "Sad" response!
In my van's case the noise is sporadic and might happen at any time, even when the monitor isn't activated. Doesn't matter whether we're parked or on the move. This, too seemed to match the OP. When I'm in the front half of the van, it sounds like it's coming from the roof -- another similarity. Sat in the cab, it sounds like it's coming from the overcab -- but then the monitor replaces the rear view mirror rather than being dash-mounted, so I assume that it would sound like it's coming from the wheel arch area if it was dash-mounted -- another similarity?
Our system doesn't turn off with the ignition but has an isolation switch, so I can shut down the system completely. Leaving it on can flatten the cranking battery over a few weeks and hence I try to remember to open the isolator as part of the park-up routine.
We too have the reversing cammonitor over the mirror but that goes off with the ignition on ours.
It is a damned pest not being able to figure it out.
