Any pointers to where I can purchase?
runnach
Also what the part is called. They are fitted to front of van, where the window washer tubes take water up to each wiper for screen washing.
Nipple on one has broke, the other, see image, this has sheered. Basically one part screws into the other. Any info greatfully received.IMG_3354.JPGIMG_3355.JPG
Thank you for your replies, gents. I've fashioned a joint for both screen lines for now, I'll measure ID of both tubes, then order appropriate reducer. I have replaced the tube that is outside bulkhead and exposed to UV, the original tube has age and UV hardened, making it brittle, new tube is more supple and should do the job..........Cheers.
Try C A K , Kenilworth 01926 854271
It is called a BULK HEAD REDUCER If they can't help there supplier should have it, hope this helps
I will check them out GG, thank you for your help and input...............cheers.
