Garmin Camper 780 Satnav Update Issues
marchie
We have 2 x Camper 780 Satnavs arising from the M/Home arriving with a duff Multimedia Unit in April 2021 [bought one as a 'temporary' solution pending the Multimedia Unit repair, which proved impossible so the Dealer sent me an Avtex Camper Two version!]
I had purchased a 32Gb micro SDHC for the Garmin 780 [Satnav Internal Memory has 13.8Gb used of the original 16Gb] in 2022 and had about 24.8Gb free from the original 28.8Gb, so assumed that that would be enough for the Map Update. I also planned to downoad the WildCamping POI Files. The Map Update crashed throughout the day on Tuesday on several occasions, and again yesterday after a 3 hour+ snail pace download attempt. I had checked with Garmin Support that I could use a larger capacity micro SDHC Card and they emailed an Instruction Sheet stating that the 780 can handle cards from 4Gb to 256Gb, so Tuesday morning I bought a 64Gb micro SDHC Card and followed the Garmin Instructions to format the Card in the laptop
The formatting went ok, but, when I tried to use the 64Gb Card in the Garmin 780, the satnav couldn't find it, and I got a message 'insert a Card between 4Gb and 32Gb'. Garmin Tech Support were adamant that a 64Gb Card would be no problem! After yesterday morning's failure with the existing 32Gb micro SD, I trotted back to Argos and ought 2 more 32Gb Cards ['Weren't you in yesterday for a Card?'!]. Inserted the new 32Gb Card in the Garmin 780 and about 5-10 minutes coughing and spluttering very slow update, until it sprang into life, moving from about 7% complete to 50% complete in a few seconds! 15 minutes later, the Map Update was fully installed!
Repeated the process with the 2nd new 32Gb Card and the Avtex 780 [also about 13.8Gb Internal Memory usage] went straight to a 27% complete message, and finished the Installation in under 10 minutes! I copied the original 32Gb micro SDHC Card from the Garmin 780 to my Samsung SSD, and then formatted he SDHC to act as a new, 'clean' Card for the next update. Easy, eventually!
The Garmin Technical Support advice and their Manual is wrong; I wasted £11..99 on the 64Gb Card and 2 x 18 mile journies to buy new 32Gb Cards, and the repeated 'Loading Update' failures ate over 22Gb of my Monthly Data Allowance which had renewed only 4 days earlier, so I had to stump up £15 for an additional 15Gb Data Top Up! I haven't dared to try downloading the WildCamping POI's yet; don't think my heart can take it ... :ROFLMAO:
I've given up trying to update my Garmin due to issues with SD cards not being recognised. The good news for you is that the WildCamping POI zip files normally come in at under 1.5MB (yes MB).
