New cable
Exwindsurfer
Well I have just up graded my 35mm cables to 70mm as the 35mm were getting warm if I used the 2000watt induction hod .I gave them a try using a 2000watt heat gun that I ran for just over 10 mins and everything was fine now I've just got to sound proof the front doors .
hi. my mate has 2 red & 2 black 25mm cables for battery to inverter which came with the inverter . i all so had the same but someone said change them for 50mm cables which i did but my mate said 50mm cables are the same as 2 25mm cables if not better than because there is 2 / 25mm per connection leaving air around to keep them cooler than 50mm .what do you guys think . cheyenne
Don't think it makes any difference. You need thicker cables if the inverter is not near the battery. Two cables would be neater and easier to fit an inline fuse.
my mate fitted 50mm cables & his battery's are next to the inverter weeks ago .cheyenne
I don't think you mean 35 / 50 / 75mm cables.
