Help request
Paul Fear
Hi folks, in need of some urgent help. I have a Ci Carioce 656. Turned on the water, opened the tap but nothing. No pump sound. It was Working perfectly last week, now nothing. Any ideas which fuse it might be and where?
Thanks, Paul.
No isea but could also be micro switch or stuck pump, investigate after if and when you find the fuse.
Thanks, Paul.
Between your seats by hab window might be the pump electrics. Unlock the box and see if you have a loose connection. Thats what happened to mine. I fiddled and it has worked ever since.
Alternatively behind your drivers seat may be a small black metal box. If you take top off you may find a fuse box for various things in the van.
Hope this helps. May be talking out of derriere as not used to giving technical advice but this is what I have learned with my CI
