Rumour
Electrical warning. I had been having trouble with the sporadic operation of my Eberspacher diesel heating system. At first we thought it was the batteries, but they are all good. Then someone told us that on some installations, the electrical wiring to the main heater unit may not be enough to power it up. So we decided that on our return from Blackpool, I would take a look.
We had just driven out of Blackpool when I noticed a high pitched noise. Had no idea where from but as I looked in the back through the mirror, I saw smoke! I pulled over and went back to investigate and found nothing obvious. But the smoke was getting worse and toxic! I lifted the seat cushions and opened the hatch into the side locker and there it was. Under a fitted rubber mat, was a tangle of wires. They had all seemed to have melted together. I disconnected the batteries and solar and the smoke subsided. (at this point, I was having a little difficulty breathing, so I got out of the van and took a rest.)
On looking at it, I saw that the had powered the heater from the inverter cables. They were much better able to handle to power loss over the 4 mtrs run. But they hadn't renewed the wire to the heater with a heavier gauge! Hence the heating of the mess under the seat! The thing is, the heater was not being used, so it was drawing no power. It happened during the day, so it made me think what if it has done that at night, while we were asleep. The smoke alarm didn't go off until I tested it and silenced it, then it went off! So it looks like I have to replace the whole thing at silly money.
BUT.. Although I am sure this is not really necessary, CHECK YOUR WIRING!
