engine battery change
cheyenne
hi guys. thinking of changing my engine battery fiat ducato 2.3/150BHP i think its a 110AH not sure as on storage at mo any recommendations thanks.cheyenne
Depending on the age of your van it may well need an AGM battery, you will need the battery numbers of the battery before you order a new one,
Best thing to do is fit as high a capacity as will fit.
The underfloor battery box is setup for a Group 19/G19/019 battery size for length and width. Height probably no more than 200mm
If staying in storage, why change now? wait until the spring.
hi thanks for that no we will be replacing the battery in the next few weeks as we always go to Malaga for the winter . any recommendations of makes anyone here is the readout of my battery on the 29th for some reason dropping down . the wife said as we was approaching the ticket check-in at the tunnel i stalled the engine :unsure: so it makes you wounder BUT we have never had any starting problems we the battery failing to start the engine . cheyenne
