Cost us just over £100 for 2 lightly used 6kg gaslowWish I could afford to do that & not have to rely on EHU.I know it would probably pay for itself in the long run.
Can't be doing with rattles either so try and eliminate as much as possibleTurning the plate rack 90° and putting the cup rack on the wall below the cupboard it was in, getting a cup holder that I can reach with my right hand easily. putting the grill pan on a silicone mat and the rack inside ditto, I hate rattles, we switched from saucepans to frying pans, easier to stack clean and use, and a silicone mat between them and the live on the once rattly oven shelf.
Already have one Refillable Gas plus one Calor Bottle was thinking more on the Electric side.......as Wildebus said Inverter to not to be relying on EHU Points.Cost us just over £100 for 2 lightly used 6kg gaslow
And pipework ....
Only bits I didn't get were fill pipe and external filler .
Costs me just over £20 to fill both from empty .
Ahhh fair enough ...Already have one Refillable Gas plus one Calor Bottle was thinking more on the Electric side.......as Wildebus said Inverter to not to be relying on EHU Points.
We put paper plates in the rack in-between the Croc plates to stop em rattling around.Can't be doing with rattles either so try and eliminate as much as possible
I took out the plate rack entirely (space-inefficient I thought as well as rattly) and instead I bought a couple of sets of separator pads like these - https://amzn.to/46mUXia. Have one between each bit of crockery and between the various stacking saucepans.
Very pleased with them (and of course, yes you can use old teatowels or cloths instead and not buy things like that. Just pre-empting the 'coulda shoulda' brigade)
Also, handy thing I use is a Drying Mat which lives inside the cooker hob to stop the lid rattling and then comes out to act as a, oddly enough, drying mat for washing up (why do Motorhomes virtually never have any kind of draining board?). Mine is from Lakeland and is quite long and a perfect fit for the hob. Most seem to be a bit shorter?
Ours came with something like this, it has a slot in the cupboard under the sink, I also have a small drying rack for plates.Can't be doing with rattles either so try and eliminate as much as possible
