Just about anyone who is a Victron user will be familiar with putting in the 6 zeros when connecting to a Bluetooth enabled device for the first time.
Well, it seems times might be changing .... I was just checking a new Victron Orion-Tr Smart B2B and it refused to connect. Most Annoying!
Looking at the labels supplied, it looks like Victron are now supplying a non-000000 PIN number with these Orions. There is actually a PIN number supplied with the PUK label and also a PIN number on a label stuck on the side of the Charger.
Using this printed 6 digit PIN I could connect successfully.
I am not sure how long Victron have been doing this (never got a non-000000 device supplied before), or how widespread this practice is/will be. I got a Victron SmartSolar MPPT at the same time and that was still at the usual 6 zeros default.
So just a heads up if you get a new Bluetooth enabled device and you can't connect ... check for labels with a PIN number on it. (These PINs are apparently generated randomly so if you did have a brand new Victron setup I could envisage every device possibly having a different PIN! Well, it is one way Victron can make sure people really DO reset the PINs to something else
