marchie
The battery is sitting inside the M/Home, fully installed, but not getting a great deal of daily work [with the exception of running the water pump during the water tank sterilisation and the water heater descaling about 10 days ago]. The new MPPT 100/30 Controller is working like a dream and seems less inclined to throttle the solar harvest as the predecessor 75/15 seemed to do.
The Roamer BMS is far more sensitive than the predecessor KS Energy 120Ah Lithium, and yesterday, it flagged up an 'Undercharge' Alarm, because the battery temperature fell to 4 degrees, despite being in an inside battery box under the nearside habitation sofa, so not getting lots of draughts from the Cab. Roamer tell me that the Alarm [Code UTC1] will reset/disappear when the temperature warms up and tha Battery temperature rises above 5 degrees Celsius. The M/Home is parked outside in an on street parking bay, directly opposite the Firth of Forth, which is 100m away, and a wee bit breezy during Winter ...
Has anyone else had the 'Brass Monkies' Alarm, and would it be wise to leave the gas heating on at a Frost Stat setting or similar, say 8 or 9 degrees?
