Ah. All the current ones have Faston Tabs (Ablemail changed from Studs as it was overkill for the currents involved).
If you are connecting two panels in parallel, you would be best off doing that on the roof to save having to make another hole in the roof for the second pair of solar cables.
The significant majority of panels on sale use MC4 connectors. To parallel join a pair of panels with those connectors, use something like this
https://amzn.to/3URBRin - MC4 Splitter/Combiners. The one I linked to is just one of loads of ones listed.
If you don't have MC4 connectors (some panels such as Truma brand use another style), you could cut the cables and add MC4s and then use the combiners, or cut the ends off and use the following connectors ....
https://amzn.to/3IbVQ3D - Wago 221 Lever Connectors.
They will take upto 4mm2 cable, which will be enough for any solar panel and for the cable Burstner will have fitted.
You would have the +ve of one panel in one of the three, +ve of the second on the next of the three and then the cable into the roof into the third position.
You use one 3 way for +ve and one 3 way for -ve. Need to put these into a little box and make it waterproof.
The MC4 method is generally the easiest and what I would recommend if you have the option.
Bit of a write-up on the MC4s here if interested ....
https://wildebus.com/posts/solar-panels-connections/
