Val54
Our motorhome is on a 2015 Fiat base and this afternoon the starter battery only just cranked and started. Its the original battery so I'm happy that its time to change it. Now I'm still fairly handy with the spanners but when I lifted the floor lid I was a bit taken aback by the amount of wiring ..........
I've looked in the Fiat handbook which isn't exactly forthcoming on battery replacement ....
I've had previous issues with airbag CPU failures so I don't want to cause another failure. All I've gleaned so far is to disconnect any linkage between the hab batteries and starter battery, then disconnect the negative and wait 10 minutes or so before proceeding to remove the battery. Installation being the reverse process. Any advice in addition to that. Also I was planning to order the same size battery but with a higher CCA, ie 900 rather than the existing 800. Is there anything else to watch out for, I'm assuming that as it is 2015 van with no stop/start, it doesn't have a smart alternator, not sure how to double check that.
Helpful comments/advice appreciated
