Well I’ve started
You can go using that Geoff you will flood the van out, can’t have big gaps and holes in the wall. Do buck up chap 😂😂😂
What heating do you have for hot water ? Are you using your solar/ electric to heat water
I know it’s too late now Jeff but will you have to park in a certain way, in order for the water to drain away?
Many motorhome shower trays have two drains on different sides of the tray.
PITA Rog, one way for the shower, total opposite for the kitchen sink, thanks Swift for the joined up thinking.
I’ve desided to put a shower in the toilet compartment I am using a house hold shower tray 1000 mm x 700mm as you can see it’s a lot of work and should have done it years ago because of the width of the tray I have had to move the front wall a further 40mm out luckily my wood floor is 70mm above the steel floor of the van so not a prob getting the wast in place .View attachment 71641View attachment 71642View attachment 71643
The other picture are a bit blurred. You can see how much I've moved the front wall so the shower tray fits going to have to try and get some fablon to hide the bare wood.
