NEW...Victron Energy Orion XS 50A DC-DC Charger
It looks like an handy update, especially with the VE.Direct port, which was very sadly missing from the Orion Smart-Tr.
I was speaking to one of my distributors this afternoon and will be adding that to my shop at a very competitive price once availabily dates confirmed :)
The new one isn’t supposed to get hot like the old ones is it
They revised the Smart-Tr units so they didn't get quite as hot anymore.
Anyone who has an early one that does get very hot can check the serial number and if before a certain range, Victron will exchange for a new one.
There used to be an app by that name to search Ebay, I managed to blag loads of good stuff cheap, but Ebay shut it down a few years ago.
Would it be suitable for my nuevo with sargrnt 328 set up I was told their was an issue with a BtB and sargent 328
, somthing about a loop causing a battery drain ?.
The Sargent has a built-in Split Charge system, so if you added a B2B (any B2B) the two would be in operation together and you wouldn't get the best from a B2B due to the limitations of the Sargent.
The thing to do if adding a B2B would be to disable the Sargents B2B operation. There are a number of ways to do that (My own favoured way is the snipping of a specific wire so the Sargent simply doesn't know the engine is running).
I think I know why there is an idea about there being a loop but it wouldn't cause a drain and if you disabled the built-in split charge function you would remove any loop situation anyway.
