Interesting. Have you put a code reader on to see if any errors come up?Someone on the Fiat Forum posted this link.
Is Your Mileage and clock Flashing at you while you drive? | FIAT 500 (2007+)
The dash does this to warn fiat Tech's that the accurate clocks in the dash pod and the body computer (that are vital for the accurate timing of the message packets sent over the can network) are not synchronised. If it is flashing or has been flashing then once you need to go to your dealer...www.fiatforum.com
makes sense not getting involved with the 240V side if you can avoid it.She came over FOC to sort out the mess her colleague had made fitting the MPPT controller.
We worked out that he was doing a decent job of the wiring but then he cut a cable to fit a fuse and found he didn't have one with him so he just connected it up and put a shrink sleeve on it, fastened it all back up cover on etc and said nothing, she's like me and knew enough to be dangerous, but she's been on some courses and she's up to speed on the 12v side of things now, she is not going to get into 240v as she can call on someone for that, and she rarely needs to get involved with it more than changing a socket etc.
motorhomer.com
