Dropped and gone saggy over the years
Sonar
Yes it’s dropped and gone saggy over the year. .we’re talking fiat Ducato 2003 motorhome .
The front springs. I don’t know of it’s worth seeing if I can gat longer springs or not .
Had the front suspension legs renewed a few years ago and used the same springs.
There real thick and in good condition .
Seen on the net a company called mad springs they are in Holland or somewhere like that and there not answering emails ..
They make a spring that goes inside the main spring and offers that little extra lift.
Other ways like rubber inserts or rings that go in the spring I have been told is Not an option ..
Any other options. Anybody ?
An option I used to see a lot mentioned in the US on RV Lifers Youtube channels was "Sumo Springs" and they seemed well liked.
I think they are now officially imported into the UK/Europe and while usually seen on the rear, I think there are front options as well?
I don't know if it is the type of product that you have been advised is "not an option" though?
Have a look at this website as a starting point - https://www.superspringsinternational.com/sumosprings/
Mainly rear springs only one for the front and that’s the rubber insert that I was told by an engineer never use then on the front there o.k for the rear. Only..
Don’t know why but there it is
Look on Fleabay the springs are manufactured by Kiln and used by a well known air assist suspension installer.https://www.ebay.co.uk/itm/275358897981?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qY9ep60iTl6&sssrc=4429486&ssuid=_TTYNRZBQU6&var=&widget_ver=artemis&media=COPY
P.S. these were the springs for my model of chassis so check to suit yours, they were also h/d. I also doubt you will get extra height with the springs only hold the vehicle at its given ride height.
I put 40mm spacers on the top of my springs to lift it a bit + the rubber inserts in the spring and had no trouble with then that was about 18 month ago replace the top bearing as well all brand new
