Discounting the volume of water heated and you only need enough to wash the dishes, which is the best use of gas?
Liz says that the kettle is best because it uses less gas for the same amount of water, kettle is 0.5L so not enough in one hit.
I say the water heater will be better as the gas only heats the water not the room and you get all the water required to do a better job.
Plastic washing up bowl used.
