NRF Blind & Flyscreen Installation
Sharon the Cat
We've worked out what goes where, but don't want to use screws to fix this up. There is no blind there presently so it's a virgin bit of body on a brand new coach built. I think I saw somewhere that someone fixed theirs up with Gorilla Glue, but there are lots to choose from.
Thoughts or recommendations would be welcome.
Screw it up
A dealer would use screws to do it
Thank you, but my worry is that a dealer could also use such screws as an excuse to invalidate the warranty. I have found someone who used Clear Gorilla glue and says it has worked a treat.
The alternative to glue or screws would be heavy duty velcro cut to the frame size if the interior wall is smooth enough.
The velcro then has to be stuck on. In my experience even the heavy duty stuff is only good for exhibition panels and the self-adhesive stuff doesn't last.
I think I'll be going with the Gorilla Glue, thank you.
So basically any additions you add could however invalidate the warranty if that’s the case you may have to get the dealer to fit the blind.
Maybe just an addition will invalidate the warranty. Without written details.
I'm just erring on the side if caution by not making holes in anything too close to the body shell.
Just thinking again about the type of glue, the self-builders and installers would use something like a white Sikaflex 556 bond as a goto fix.
Just this morning bought some clear GG. I'll be back to check that Sikaflex if it falls off.😳
Try CT 1 silicone.
