Thanks Kev.I fitted two to the self build David.
It is a clam shell, the screws are under those vent looking things, they have a Domtic name but I forget it, you have to VERY gently prise them off, I think there will be about 20 screws that go through in the out clam shell so that needs to be supported, you then have access to the blind and the fly screen.
if you prep in advance and have a comely assistant to stop the outer falling off., take the screw covers off and see how far you can remove one screw only to see how far they come out before losing contact with the outer clam shell, if it's say 15mm or so would they allow you to do it, you could buy longer screws to give more space, you could also maybe loose 3 side a lot and the 4th side a little to allow ait to hinge a bit.Thanks Kev.
I wanted to remove cover in order to tart up the wall and be able to tuck the new wall covering underneath to make it look tidy. Sounds like might be best to leave alone?
I had to take one of mine off to repair the blind, I just took it off and the sealer held the rest in place, I fixed the blind and replaced it without any problems, that was a few years agoLooking at those pics I think I'll just leave it be![]()
So easy to sort, no sealer in them as its a rubber o ring on outside, hence a 2 person job, get on with it.Looking at those pics I think I'll just leave it be![]()
Thanks least I now know what to look for if I need a new blind.Thats a Heki.
Let me know when you will be over then....So easy to sort, no sealer in them as its a rubber o ring on outside, hence a 2 person job, get on with it.
