Why Can’t Robots Click The “I’m Not a Robot” Box On Websites?
Clicking a tiny box tells Google all they need to know about your humanity
As it says in the text.Apparently they can it's just the way they do it that identifies them as a robot
Don't mess with AI , your device will self distruct and your nuts drop ofAsk AI.
I asked what happens if you mess with ai?Because their fingers are too fat
But can it click a box to prove one is not a robotI asked what happens if you mess with ai?
If you try to "mess with" or manipulate an AI in various ways, the outcomes can differ based on what you mean and the context in which you're interacting with the AI. Here are a few scenarios to consider:
1. **Misleading Input**: If you feed deliberately confusing or false information to an AI system, it might produce incorrect or unexpected responses, especially if it's designed to rely heavily on user input. A more sophisticated AI, however, may detect inconsistencies and ask for clarification.
2. **Adversarial Attacks**: In machine learning, adversarial attacks involve feeding slightly altered data (like images) to trick an AI into making mistakes. This has been a known issue in areas like image recognition, where subtle changes can cause an AI to misidentify an object.
3. **Bias Exploitation**: AI systems trained on biased data can produce biased outcomes. Manipulating these biases could exacerbate them or exploit weaknesses in the AI's decision-making process, leading to ethically questionable or harmful outputs.
4. **Ethical Violations**: If someone uses AI to break rules or cause harm (e.g., by manipulating algorithms to spread misinformation or automating harmful tasks), it raises serious ethical and legal issues. AI systems are only as good as the rules they are built upon, and malicious use can lead to broader societal impacts.
5. **Robust AI Safeguards**: Many modern AI systems have built-in safeguards to prevent abuse. If an AI is designed with ethical guidelines and guardrails, it may reject inappropriate inputs, correct itself, or limit certain types of interactions to prevent harmful or misleading outcomes.
In most cases, an AI’s behavior depends on how it has been trained, the goals it is designed to achieve, and the robustness of its safeguards against misuse.
I asked;But can it click a box to prove one is not a robot
