I don't think that it matters where you are when you renew. However, the tariff sheet gives information regarding a fair usage policy:
"(14) The use of your Réglo Mobile plan from the European Union and the French Overseas Territories must be "reasonable": a majority or exclusive use of your plan from the European Union and the French Overseas Territories will result in the invoicing of additional charges for your future uses. Over the last 4 months: - If one or more uses from the European Union/French Overseas Territories (calls, SMS/MMS and/or mobile Internet including uses exclusively available from the European Union and the French Overseas Territories) is/are more important than the same uses from Metropolitan France and abroad (outside the European Union/French Overseas Territories) AND - If the number of days spent in the European Union/French Overseas Territories is greater than the number of days spent in France and abroad (outside the European Union/French Overseas Territories), then you will receive an alert SMS to inform you, and you will have 15 days to modify the use of your plan. At the end of these 15 days: if you comply with at least one of the 2 rules above, If your plan usage becomes reasonable again, you will not be charged any additional fees. If you still do not comply with either of the above 2 rules, you will receive a new SMS alert informing you of the immediate invoicing of additional fees for future unreasonable usage from the European Union/DOM.
Additional charges: outgoing calls: €0.0228/min; incoming calls: €0.009 incl. VAT/min; outgoing SMS: €0.0036 incl. VAT/SMS; incoming SMS: free; outgoing MMS: €0.0015/MMS; incoming MMS: free; Internet: €0.0015/MB. As soon as your plan usage becomes reasonable again, you will no longer be charged additional charges and will be informed by SMS.
Where it refers to the EU, obviously it means the EU outside France.
That's why I didn't use a translation engine; they get things wrong! The (flagrant) error that immediately stood out to me is one that won't concern you; I haven't checked the entire translation."(14) Use of your Réglo Mobile plan from the European Union and the French Overseas Territories must be "reasonable": majority or exclusive use of your plan from the European Union and the French Overseas Territories will result in the invoicing of additional charges for your future uses. Over the last 4 months: - If one or more uses from the European Union/French Overseas Territories (calls, SMS/MMS and/or mobile Internet including uses exclusively available from the European Union and the French Overseas Territories) is/are more important than the same uses from Metropolitan France and abroad (outside the European Union/French Overseas Territories) AND - If the number of days spent in the European Union/French Overseas Territories is greater than the number of days spent in France and abroad (outside the European Union/French Overseas Territories), then you will receive an alert SMS to inform you, and you will have 15 days to modify the use of your plan. At the end of these 15 days: if you comply with at least one of the 2 rules above, the use of your package becomes reasonable again, you will not be charged additional fees. If you still do not respect either of the 2 rules above, you will receive a new alert SMS informing you of the immediate billing of additional fees for future unreasonable use(s) from the European Union/DOM. Additional fees:
calls made: €0.0228/min; calls received: €0.009 incl. VAT/min; SMS sent: €0.0036 incl. VAT/SMS; SMS received: free; MMS sent: €0.0015/MMS; MMS received: free; Internet: €0.0015/MB. As soon as the use of your package becomes reasonable again, you will no longer be charged additional fees and will be informed by SMS."
Fine, if that's what you want, but if you don't top it up it stops working after a month, and then if you want to carry on you're buying another at a cost of €5 for the card on top of the month's subscription.All I want to do is walk in, buy a SIM and put it in my phone; that's all I did with the Three SIMs.
Should be fine for that.Just smurfing, streaming, forums etc, but Liz would be hotspotting off it too.
