Bracknell MoHo
Hi,
Looking to pick the minds of the hive collective. Setup: kitchen tap is of the fold down type, with a lid that comes down to cover the sink. Sometime back I switched from the system being microswitched to pressurised. It already had a Shuflow pressure switched pump on the system, but was triggered by micro switched taps. I essentially too the microswitches out of the circuit to run it as pressurised. Its a 20psi pump which while not the original pump that was on there was a like for like swap a while before when the original pump went.
The spout on the kitchen tap gets pushed off when the tap is opened. Apparently all folding spout taps are micro switched. Leading to the suspicion that they are not suitable for use on a pressurised system. Is that the case or do others have contrary experience. Thanks.
