another one in trouble !
rugbyken
after trotter blowing up his engine marie having problems and jeff having a heater leak took mine to get timing belt & service at wullys mate while up here he phoned back and said you’ve got a bent rear axle ?? couple of months back i went through a chicane & clipped rear wheel causing a dent in the rim put spare on and got a new rim & tyre from e bay , been driving around without a thought but this is definitely bent causing tyre to wear on inside new part £750 sweating on delivery though quoted 9th july which will make my 12th crossing tight
Ouch you must had given that wheel one hell of a wack Ken.
I just had a new egr fitted to mine. It has whistled every time it reached 2000 rpm, and when climbing, it has done this for the last three years, and frightened the sh*t out of the animals in the fields. I assumed it was the turbo, but after a smoke test smoke was leaking from the egr. When the mechanic started to remove the egr it split in two. What a difference I now have a whining from the passenger seat everytime I go above 60!!
I could straighten that in the press!
i got quoted £700 for a new axle +20% vat but got to come from italy so had to be paid for up front if i had a hope of making the orkney ferry on the 12th delivery quoted for the 9th 🤞🤞🤞, but thanks for the offer sam
And my EGR appears to be sticking, in for repair next week!
I’ve had my egr blanked off Eric, and had a remap, so the ecu doesn’t even know there’s an egr in the engine.
Had an emissions test today, during the MOT, and the readings are even better than previous MOTs, and performance is like a new van. Don’t fork out for a replacement, it will only let you down again in a couple of years.
Mines been acting up this trip, a good thrash has let me reset the code and I drop to 3rd a couple of times a day going uphill to keep it clear ish.
How much did you garage charge?
Tks Rog I think I will be going down that route.👍
