But I let my entitlement go at 70, I just turned 75 on Sunday, and wondered if it was a chore or not to get it back?
or IF you can pass the medical.I think its the same process as if you kept the entitlement at 70, I let mine lapse but Val kept hers on a just in case basis. Pretty easy, fill the form and a medical to get it back. Whether its a chore probably depends on how far you have to travel to get the medical done.
say you have a 3.5t GVW van with a 5.5t GTW - so towing limit of 2t - you can drive that combo on a standard licence.We're thinking of being able to tow as well, I believe I need the same licence for that too.
I did just that for many years, butcan I now? that used to be part of my grandad rights, a test is needed now I think.say you have a 3.5t GVW van with a 5.5t GTW - so towing limit of 2t - you can drive that combo on a standard licence.
Why a bigger van when only 2 of you.I did just that for many years, butcan I now? that used to be part of my grandad rights, a test is needed now I think.
Just in case they have a fall out!Why a bigger van when only 2 of you.![]()
As in the OP, I let it lapse.If you've had a continuous licence since before 19/01/2013 you can drive vehicle up to 3.5t and trailer up to towing limit of vehicle; (DVLA quote)
"Vehicles up to 3,500 kg Maximum Authorised Mass (MAM). You can drive a vehicle with a MAM of 3,500 kg with a trailer. The size of the trailer depends on the BE 'valid from' date shown on the licence. If the date is before 19 January 2013 can tow any size trailer within the towing limits of the vehicle. If on or after 19 January 2013 can tow a trailer with a MAM of up to 3,500 kg within the towing limits of the vehicle"
You can check your licence online and the tabs will tell you what you can drive. You need your licence number and NatIns number: Licence Check
no, that is incorrect.I did just that for many years, butcan I now? that used to be part of my grandad rights, a test is needed now I think.
I do still have a licence, I renew every 3 years, I just didn't do anything when I reached 70.Sorry, I thought you meant you’d let the C1 entitlement lapse but still had a licence. You can have the C1 reinstated by filling in the correct forms and getting the medical test. No driving test required. Some Info
I would have thought a 3.5 t m/h with trailer would be fine. That’s what we do.
