Charger upgrade
Vanterrier
I have discovered that the standard PSU4M has been removed from my 2008 Autosleeper Symbol peugeot boxer. The fuses and relays are now just a bunch of wires near the hab. battery and today I finally identified the charger as a PS276-1-BCSM unit, basically a transformer putting out 13.8v and 20 amps.
The MES panel is still in place and allows me to switch between van and habitation battery charging, but that's it 😞
Can you recommend changes that will provide smart charging that I can leave switched on while on ehu on my drive all winter, keeping both batteries charged. Ideally keeping the MES panel too.
I'm not an electrician so please use layman's English 😀 oh, I'm not rich either 😅
K ;)
those units are as dated as the one you have in place.
The approach I would take for a mains charger setup would probably be a Victron IP22 mains charger to look after the Leisure Battery plus an AMT-2 Maintainer to keep the Vehicle Battery charged when left standing.
There is little benefit in having a setup where you choose EITHER Leisure or Vehicle battery to charge as they have different requirements and uses.
13.8V makes it a power supply not a charger. On my first 2 motorhomes I destroyed several batteries before I realised that a fixed voltage of 13.8V was not enough and that the manufacturer was cheating by calling it a battery charger.
Thanks for that. For my two Yuassa 5019 100ah batteries of similar young age, which amperage Victron IP22 would you recommend? I can't see a AMT-2 maintainer? Am I looking in the wrong place or is there another digit missing like AMT12-2?
Would the MES panel still work? Would it see the Victron or be isolated from the battery charging info?
I don't suppose there's a diagram that shows the setup I need?
Apologies for dumb questions
K ;)
Yes, it is the AMT12-2, not the AMT-2.
If you were to set it up as I describe, you would not control it via the MED Panel, no.
Currently, I would go for the 30A IP22 as they are only a little more expensive than the 20A models, so may as well take advantage of the extra capability.
something to bear in mind which a lot of people forget ... when you are camped and hooked up, anything that uses 12V power - TV, water pump, lights, USB sockets, fans, USB sockets, etc - draws that power not from the hookup, but effectively from the battery, so the battery charger does not only have to charge the battery but also make up the power being pulled by the habitation systems. If you are drawing say 10A worth of 12V power (which is perfectly easy to do), then your 20A mains charger only has 10A of current to go to the battery. Get a 30A charger and although it seems only 50% bigger, you could be charging the battery twice as fast as it would have 20A left over for the battery, not just 10A.
So if I get the 30amp IP22 and the AMT12-2 do I need anything between them like an mppt controller (seen in a diagram)?
Would a Votronic "stand by charger" be an alternative to the AMT? it looks cheaper and simpler to install to my laymans mind?
So I disconnect and remove the old "charger" and plug in the IP22 but where do the cables that are in the old unit plug into?
Sorry again if this sounds dumb
K ;)
I see some IP22's are one output and others are three outputs to batteries... do I just need the one output and a trickle charger or the three outputs connecting direct to both batteries?
So many options, so confusing.
I think I will feel I know more when I finally dig out the old charger from under the oven and see what wires are going where... more but probably still not enough:rolleyes:
The IP22 3 output you can connect to 3 batteries and it will output to all three as required. You cannot control how much goes to each output and the total output is the same as the single outout charger. Also it is the same charge profile for all three outputs, so it is not like having 3 chargers in the one box.
You could get the 3 output and connect one output the starter battery, but bear in mind that will only work when you are hooked up. If you want to be able to trickle the starter when off-grid (so off solar), then that will not help
as an FYI, the Victron IP43 (a newer and bigger charger) is also available as a 3 output, so does the same thing, but also comes as a 1+1 charger, where the "+1" is a low current, lower voltage, trickle for a starter battery.
If you bought the 3 output and only used one of the outputs, then it is the same as getting the single output, so if you were offered both at the same price, get the 3 output one. If it is more expensive, then decide if that extra flexibiity is worth the extra cost. (I'd pay say an extra tenner without hesitation. An extra £50 is too much,)
I noticed the IP43 but it's a lot more expensive just to get a trickle charger built in so I'll stick with your original IP22. And it sounds like the single output will do the job.
What do you think of the Votronic trickle charger? It's half the price of the AMT12-2 but will it do the job?
Thanks for the advice
K ;)
K ;)
As far as I am concerned, the AMT12-2 is worth the extra money compared to others due to the flexibility of the product.
The Votronic unit is probably the most basic of all units and the cost of the postage would be worth more than the product (plastic case, diode & resistor)
If you are sticking to the standard Lead Acid batteries, I have a brand new CSB2 Trickle Charger for sale. This is a plug&play 4A trickle charger. Yours for £33 including postage :)
PS. There was a recall on some of these CSB2 units. The one I am selling was provided direct from CBE in Italy about 6 weeks ago post any recalls.
I like the sound of plugandplay and for that price you have a buyer;)
Pm me with payment details and I'll send payment right away.
Cheers
K ;)
Worth considering a smart charger for the habitation battery and a separate charger for the starter battery.
Yes, you can get a charger that does both, but it will probably cost more than two chargers, and won't allow for different sorts of batteries. And it's a single point of failure.
You only need a small charger for the starter battery: you are only keeping it topped up, not refilling it.
Personally, I leave the starter battery to its own devices, but some vehicles drain the starter battery rather quickly.
That's what I'm doing...
Victron IP22 30amp smart charger for the hab.
CSB3 Trickle charger from hab to van
K ;)
Hmm... just been advised that the Yuassa YBX5019 is not a leisure battery... damn!
Both batteries were fitted new about 3 months before I bought the van, so less than a year old. I'm hoping that as we mainly use ehu pitches and don't drain the battery too deeply, it will suffice for now?
K 😞
I'm not convinced that there is such a thing as a leisure battery.
A starter battery has thin plates with lots of surface area to be able to provide high currents for a short time to start a car engine and to recharge quickly.
A deep cycle battery has thicker plates with proportionately less surface area to give better storage capacity at the expense of providing high currents.
A 'leisure' battery is usually a normal car battery with a different sticker on, unless it is a gel battery.
Gel.batteries have the electrolyte in gel instead of liquid. This makes it safer when clueless users tip them over when taking them out to recharge. Otherwise they are very inferior.
If you have existing batteries and they are working, whichever type they are, stick with them.
If you want to know how good your batteries are, weigh them on your bathroom scales. Heavy is good.
For a 12v 100Ah lead acid battery of any type, one weighing under 20KG is to be avoided. One over 25KG is good. One over 30KG is excellent.
Thanks for that ;) yuasa list the ybx5019 as being 23.4kg ... I will need to stick with what
I have and hope the improved charging regime will help it last.
K 🤞
I use a numax smart charger at 10ah output, i have a switch which connects hab and starter batteries if required during deep winter.
There are others much cheaper on ebay these days.12v 20a charger.pngnumax duel.png
