Mr and Mrs Tupcox
How much for yours.I recommend mine
What can I say - if I need one, I make my own. Never bought one.
Not exactly, just what I did short term as I only needed this function to charge tools while I was building the van, and didn't want t run a lead from the garage, it got removed once it was finishedWildebus/Pudsey Bear are your replies in answer to my relay suggestion? Would be interested to learn why!! It was an idea I muted in my head before I managed to get all singing dancing inverter with automatic change over when it detected mains but certain I hear a relay click when it changes!!
My reply is specifically to Pudsey and his use of a "suicide lead" - maybe the collequial name for this type of lead tells you why they are a bad idea? Plus it does't matter how careful someone is handling this kind of lead, its use may not cause the death of the user but it will very easily kill the inverter.Wildebus/Pudsey Bear are your replies in answer to my relay suggestion? Would be interested to learn why!! It was an idea I muted in my head before I managed to get all singing dancing inverter with automatic change over when it detected mains but certain I hear a relay click when it changes!!
Would something like this work?
I've seen that type,in answer to your question I don't know that's why I was asking del.
I think it's meant to be used to switch from grid to generator so I would think you could substitute "generator" for inverterI've seen that type,in answer to your question I don't know that's why I was asking del.![]()
It needs two more contacts. You need to cut both phase and neutral
That switch will do both live and neutral, so would be ok.It needs two more contacts. You need to cut both phase and neutral
No it doesn't. The switch in the link only has a pair of contacts. Both off on 0 or one or the other on the 1-2 position. It needs 2 levels of contacts to cut both lines.That switch will do both live and neutral, so would be ok.
