Roof problem
Campingcariste
Hi,
I'm new to this forum but have owned a motorhome (or campingcar as we live in France) for 25 years. It's a Challenger 104 purchased new in 2001
The problem is with the roof which is a flexible sort of thing, to cope with temperature changes apparently, but ag the rear of the motorhome it is rounded and then joins the rar panel. This rounded section is showing signs of cracking, it doesn't appear to be leaking but it is very concerning, does anyone have any ideas?
PhilipWard
I'm no expert.
Somebody more qualified will be along with advice, hopefully
Hi,
PhilipWard
Is the rounded section plastic/fibreglass/metal? Are the cracks within the rounded section or where it joins the rear panel?
If grp its glassing cracks on the top gel coat, you can rub back and regel and must use a waxing agent to stop it being sticky, or after sanding a 2 pack acid etch then paint with a 2 pack polyurathane, this can be time consumming and expensive for you, the gel repair is cheaper if you can find a grp shp that sells small amounts.
Hi, Thanks for your reply, the roof is polyester and the cracks are in the rounded section so above where it joins the rear panel. I will take a photo and post it (if and when it stops raining!).
Did this for a living.View attachment 77260
Hi, Thanks, the roof is polyester like tge side panels although they of course are bonded o to a solid backing. I'm going to post a photo when it stops raining!!
Pending your photo, I can say that cracking of polyester on Challenger motorhomes is a known issue. You may find the following of interest:
There is also a YouTube video covering polyester repairs.
For me, the video started with a US English audio track, but this contains numerous errors of translation (including "gel coat" translated as "frost"!), so I went to the settings and changed the audio to the French original for better understanding.
Thanks I shall look at those tonight. Here are 3 photos I hope they are clear enough to see the problem. I've previously tried repairing the first cracks with fibre glass matting and resin but it wasn't really satisfactory. Ignore the painting I know it doesn't match it is just temporary.
Hi Philip,
I'm no expert in these matters, but it certainly looks worrying due to the sheer length of the cracks.. Are you aware of any Challenger owners' association where you might be able to get advice if other owners have experienced the same issue? If you use Facebook (I don't), you might have a look at https://www.facebook.com/groups/176553652783707/
Tom
Polyester is a problem to fix, you could grind the crack and fill with aroldite then paint over with a 2 pack paint, you will have to use a acide etch primer.
Hi Philip,
Tom
Salut Tom,
Thanks again. I've found the group on FB and applied to join. The links you sent me yesterday relate it seems to a known problem with Challenger and Chausson that Trigano are away of but it is cracks appearing in the capucine section (the luton). I've yet to find anything on cracks at the rear end of the roof. As I think you can see on the photos the roof has lost its proper curved shape and the cracks run from left to right and not vertically.
Philip
Salut Tom,
Philip
Hope that the Facebook group is of some use. From what I can see, you haven't tried the CCI forum, where I guess there might be more Challenger owners than on UK fora.
Tom
I went to a concessionaire on Wednesday to try and pick the technicals brain but they said they wouldn't even look at it but referred me to a car body repair garage.
So as the motorhome is 25 years old next May and I'm 77 in January I'm looking at other repair options. Don't laugh but has anyone used a product like Bostik WATERSTOP or an aluminium/bitumen tape such as the SIKA one?
The real question is whether this is in any way structural or relies on glass fibre reinforcement to retain some sort of shape. If there is delamination, simply preventing further water ingress may not be adequate. As well as car body repairers, you might consider boatyards that undertake GRP repairs - there should be some in the Charente Maritime..
I note that in the past you came to the UK for towbar supply and fitting (and took the opportunity to stock up with British foodstuffs cheaper than in France!). If that is an option in this case, you might consider the following:
There doesn't appear to be any water infiltration despite the cracks so in the end I decided to bite the bullet and I bought a 10m x 150mm roll of SIKA Multiseal. To make sure I had complete coverage I applied 2 strips with a 50mm overlap along the whole width of the campingcar at the rear about 20mm above the joint between the roof and rear panel. It looks OK, just appears as a grey stripe along the width of the roof, I can post a photo if interested. It can be painted which I may do in the Spring but it doesn't look too bad so as long as it solves the problem it might just be a case of "handsome is as handsome does".
Before you try to fix it, decide what you are seeking to fix.
Waterproof tape won't stop any leaks, because you already said there are no leaks.
You seem to be concerned about the structural stability of the section, with cracks spreading. Hiding them with tape won't help there.
As a general rule, try to fix it properly the first time, rather than slapping on a fix that won't last.
Sorry I can't suggest what a proper fix would be. Just that you should look for one.
