Admin
Administrator
I was getting ready to put 2x200 watt panels on my roof, but when I saw how flimsy the mc4 connectors are I went a different route.
I replaced the 4mm2 wires coming from the rear of the panel with 6mm2, to these I attached 10mm2-25mm2 Dinse style welding plugs female on the pos side & male on the neg, these will go into a Y connector made up out of 10mm2 wire & Dinse plugs.
The single wires coming from the Y connectors then travel along the roof & in to the victron MPPT controller 10mm2 wire is the biggest that the controller will take.
Why have I done this, it's about cutting down resistance in the wire & connectors & it's about the quality of the amps getting to the batteries.
The mc4 connectors create a sort of road block that Dinse connectors do not, so the power can travel in a cleaner, easier fashion, upping the wire size does the same thing.
Word on the web is that I will get about 5-10% increase in power collection.
When I said I was getting ready, well that was until I was admitted to hospital after being told I had Heart failure. Got to take it very easy for a few months so everything has been put on the back burner for now.
Phill
This really depends on the voltage of the panels, 60v panels won't suffer much with the tiny resistance added by the mc4 connectors. The resistance causes the voltage to drop slightly and the current to increase.
