On pressure testing one battery was below 12v and the other less than 10v so assumed they had been abused and replaced with two 110Ah gels.
I think you made the right move in fitting Gel batteries
. My 2001 Hymer has the original SL80 Sonnenschein Gel Leisure Battery 12V 80Ah battery fitted, and it's still going, I fitted a 140w Solar Panel last year. The MH has sat around for some considerable time in the last few years, covering 1-2,000 miles at best per year, but overall it has done over 100,000 miles. I am in the process of reassessing my Solar and battery needs. Never used the microwave and always wild camp, so that is my aim. I also have an electric bike now, I let her have a go last week, she couldn't believe how much fun she had on it. I suppose I will be buying a second bike for the summer now, then a higher output alternator.
If replacing the battery I will be fitting 2 of these
https://www.ebay.co.uk/itm/12V-110-...=item1c7bdb194f:g:teQAAOSwjDZYkdTS:rk:33:pf:0
They are not the same size or fit as my original battery but I can work around that for the extra benefits and warranty that this battery will give me. With Gel batteries you have to make sure that your charging circuits are set up correctly, they have a maximum voltage as stated by the manufacturer. My SL80 is max voltage of 14.4volts, the Powabloc is 14.7volts, under engine power my leisure battery is charging at 14.51volts and I think it was slightly higher under mains, so I wouldn't keep it connected to the mains for long periods of time. Need more sun to check the Solar.
I will be doing a test like hairydog suggests in post 11, but with a 5amp load, I will also see what my low voltage cut out disconnects at, on both the Gel and Lead Acid battery setting. Once I get the figures I should be able to gain some knowledge of my battery condition and system settings.
