Admin
Administrator
Rutland Water Rally
The dates are 23rd to 28th May 2019 (Spring bank holiday weekend).
This will be a large meet. It is not possible for everyone to sit around the same campfire, so we will not be having the main fire. If you want a fire you will need to bring your own firepit and fire blanket. All fire pits must be raised off the ground and the grass must be protected.
This means that there will most likely be some smaller groups in the evenings.
You can arrive early or depart later as this is a campsite.
There is a charge of £8.50 per van per night.
The site has Water, elsan points and rubbish disposal.
There is more information at the website http://www.lyndontop.com
Post-Code LE15 8RN Not the Lake District one found on their site. Site grid ref 52°38'16.4"N 0°40'30.4"W
The turnoff to get to site https://www.google.co.uk/maps/@52.63...x7iw!2e0?hl=en
For those that have not been here before the postcode is not exact for the site. The sat nav will stop before the entrance. If you are coming in through Manton continue past the garden centre on the left and take the next left towards the nature reserve. This is a single track road. Follow the signs for Lyndon Top Campsite, the entrance is on the right, it is not the first campsite you come to on the left.
When you arrive you will see some new barriers ahead of you, if you don't have the code you will need to turn right before the barn and go around the back of it to the check-in point. Please tell them you are with Motorhomer and they will direct you to our area, which is the same area as we always have.
If you are happy that you know where you are going on the site please PM me and I will give you the gate code, they have set up a code just for our group at this rally.
If you can have your payment ready on arrival with the correct change that would be a big help.
Other useful links;-
http://www.discover-rutland.co.uk/
http://www.rutlandwater.org.uk/
http://www.rutland.gov.uk/transport_...urist_bus.aspx
Can I ask that members do not park their vans right next to the tap points. We need a large area in the center of the area for the tents and fire pits, so if you arrive before me on Wednesday and have parked in a reserved area, I may ask you to move.
