Ferkel
Quick Q. Is it safe to use a power wash to clean a motorhome due to the various seals etc.
I own a STIHL professional power washer which has 2 different power setting and 2 different types of nozzles.
I used to own a caravan site in France where we also stored caravans all of which were cleaned every single time we pulled them out of storage before positioning onto their pitches and I always used the pressure washer.
On UK built caravans I always had to be far more careful because of the amount of vinyl decals and the generally low quality build techniques employed by the British manufacturers, whereas on the Europe mainland manufactured vans we stored you could do quite literally anything to them and they came out shining!!
But in general, if you use your noddle and keep away from the main mastic joints, window joints and roof light joints then you should be OK.
You can use a power washer Marie, just don't get the nozzle too close. They have machines that use a a water jet to cut steel plate. So if your not sure, get a proper brush for the job, bucket with soapy water, and do it "old school".
Marie, what's the stuff you mentioned... silver sand? I don't have a pressure washer either and I struggle to keep the black slime at bay on my patio.Most of the jobs I do already are 'old school', Debs
If I went out and bought all the modern tools affluent folk acquire (like pressure washers), well... I couldn't afford it, especially not now I've just spent nearly every spare penny we had on a new(er) van!I can borrow one, but think I'll stick to what I know & have already.
I cleaned the whole of our block pave driveway last year with an ordinary hosepipe and sprayer, with the nozzle set to 'jet' (we have good water pressure on our taps anyway, which helps). That included getting all the cr*p out between the pavers and re-doing the whole lot with the silver sand stuff once it was clean & dry. It did the same job as a fancy pressure washer, even if it probably took a wee while longer, but so what?
Depends on the job you're doing, of course, but 'domestic' pressure washers can sometimes be a bit crappy & overrated (I know, I have used them elsewhere). A normal hose will wash a vehicle just as well (and more safely by the sound of it) imho![]()
