I have been looking at options to allow me to leave my small Trailer at home and still keep the inside of the Camper free of gear so I can use it overnight while travelling to and from shows.
Decided on using the Thule EasyBase as the main part as all the Thule gear I have bought in the past has been rock solid
Thule EasyBase Carrier Base Unit Tow Bar-Mounted
It wasn't suitable as Thule intended though, so first step after putting the base together was remove the right hand upright support where it fouled the door mounted Ladder
Base offered up and upright cut down by David, on Flickr
(I also adjusted the ladder position to make it higher so it cleared the main base part)
The upright pole as shown in the first [Thule] photo I wouldn't have fitted anyway as it would have also fouled on the Spare Wheel on the left hand side.
On the bench and this is what we have
Thule Carrier by David, on Flickr
Took some mesh I had hanging around and cut it to match the Easy Base platform
Thule Carrier - Mesh Offered Up by David, on Flickr
(Thule do sell an "EasyBasket", but that costs around £100 or so, so quite pricey for a bit of shaped wire mesh)
Bit of wirebrushing and then some paint and primer made the mesh a lot tidier.
Then some Neoprene Foam strips put on the base to provide some anti-vibration & anti-rattle support for the mesh; Then bolted it down using Roofing Bolts with Penny Washers at the top and standard washers and Nylock nuts underneath.
Strategic trimming in the mesh was added to allow access to the towbar securing bolt
Mesh Cutout by David, on Flickr
And fitted into place ready for use
Thule Carrier with Mesh by David, on Flickr
I need the numberplate (and will put a yellow one on) as when in use the door mounted plate will be obscured, but not sure if I need the lights though? the standard lights will still be visible, but the carrier is 700mm further back from those lights which may be too far?
