saxonborg
I have a low line Buerstner T660 Nexxo, this is an overcab shelf which is boarded in with three panels which fit between shelf and the GRP pod. Last year I decided to add some recycled plastic wool insulation behind these panels because I thought it would be a good idea for sound deadening and heat retention. In the last week or so I needed to remove these panels to add some wiring, whilst poking about I noticed the insulation was very damp at the point where the GRP pod is fastened to the cab metalwork. I have now removed all the insulation and it has dried out completely. So is this something I shouldn’t have done, or maybe insulated it differently. I would add that the GRP pod has a lining stuck to it which extends part way down behind the removable panels but then there is a bare section of GRP where it is attached to the cab frame over the windscreen.
