Exwindsurfer
Yes your right the bank account is much lighter lololol.Are they as light as your bank account is now![]()
I am well please Eric the way it’s turn out .All you need to do now is wire your van to your house and you will be able to run off grid.??
There no need for venting Gordon so Phil says .Do they have any venting on them jeff ,just curious
Very true lololWeightWatchers are cheaper !
I thought they where lipo but Phil informed me they are lithiumYeah wasn’t too sure as the type of battery that they are ,curious that was all ,skinny wee git you are losing all this weight aghhhhhh?
With 2 batteries haven't lost capacity, rough 100AH? I know they charge quickly so you maybe able to manage without the extra capacity.
Phil,You can only use 50% of a lead acid battery's capacity. (3 x 175) / 50% = 187.5 Ah. These lithium batteries can deliver the full 100% on every cycle and still achieve over 2000 charge cycles above 80% capacity. So 200 Ah total.
The real magic if is you use an inverter as LifePo4 batteries do not suffer stamina issues under higher loads. Also as their charging efficiency is 20% - 28% better than lead acid, you actually store 20% more energy from solar.
